fjpompeo
Advanced Member level 1
lm723 2n3055
I know that this is a very unusual configuration so I need a schematic of a linear psu that uses a centre tapped trafo and a two diode in a negative configuration but uses a 2N3055 with the colector connected in the tap of the trafo, I mean the positive rail has it's output controlled with this 2N3055 and the negative output is connected direct in the anode of the rectifires.
Awating to hear from you,
Regards,
Fernando
Regards,
Fernando
