pss analysis for LNA in cadence
balu304
Member level 1
Member level 1
hi
i designed a circuit for LNA.i simulated for s parameters.i wanted to do pss analysis to find out 1 db compression point and iip3.i am getting problems by setting the analysis(specifying the parameters in the analysis window).can anybody help in this regard..or post any help material regarding this.
how to set the pss analysis window.......?
thanks
I have not idea how to run PSS. I get an error message:
control(0) Autonomous Circuit missing AUT0 on PSS
Is there an application note or a working example on how to run a Third Order Intercept Point simulation?
Sincerely,
Leon
i am posting one document.it may help u to find all characteristics reg LNA.if not tell me,i amy post few more docukments.....ok....
Reactions: sh_v
    V
    sh_v
what kind of problem do you encounter with it? can you explain more.
