PSRR in DC is only -38dB- any ideas?
chang830
Full Member level 5
Full Member level 5
PSRR in DC
I am designing an amplifier. I found the PSRR in DC is only -38dB in typ. I am trying to check out why it has so low PSRR.
Anyone pls. shed some light on it?
Thanks in advance
Re: PSRR in DC
Thanks in advance
it depend on your open loop gain of your opamp, try to increase it, you will get better psrr
    chang830
Re: PSRR in DC
Thanks in advance
In fact, my block is in closed loop work and has fixed gain of 6dB. I guess there is some leakage from supply to output, but how can I to foound it out? It has mitiple stage, so I don.t know how to check....
Thanks
Re: PSRR in DC
chang830 said:
Thanks in advance
Thanks
just Ac=1 at power supply VDD
and run AC analysis, plot the vout/VDD, you will get psrr
but remember PSRR must run in closed loop.
Re: PSRR in DC
surianova said:
chang830 said:
Thanks in advance
Thanks
Yes, it can give me the PSRR value, but did not tell me why it is so low? Abd it also can not tell me what's the leakage path?
Any good method to help on ot?
Thanks
