PSpice VSIN Phase Sweep, wont work!
electronZ
Member level 2
Member level 2
Hey 13375!
I have a small problem, i cant make a phase sweep in PSpice :/
I want a plot where i can see the result of decreasing the phase. I have created a parameter which i substract from the phase.
but it keeps giving me a plot, where the phase is unchanged.
whats the problem?:|
I think you should use the transient and AC sweep mod in setup analysis .and another things which is important is that you put different value which needed for your sources.
regard
pesarirouni
make complete phase parameter value as expression phase = {2.42 -{A}} and then use parametric sweep option and sweep GLOBAL variable "A"
thanks, i will try that!
---------- Post added at 15:15 ---------- Previous post was at 14:48 ----------
Epic! Excellent contribution, Sir. It works! :-D
