PSpice question - using parameters in simulation settings
narwhaler
Newbie level 6
Newbie level 6
Is it possible to use a global parameter in the simulation settings? For example, I have a parameter called TH which is used to determine some component values in my circuit. I want to run a transient simulation, the length of which depends on the value of TH. So I put in the simulation settings window {4*TH} for the "Run to time" setting. This causes an error:
.TRAN 0 {4*TH} 0 1n
ERROR(ORPSIM-16152): Invalid number
Is there a way to use this global parameter in my simulation settings?
I am not sure if you can use a parameter for part of the simulation statement (I am not able to try it at the moment) but you would need a .param TH= ... statement - do you have that?
Keith
I do have the parameter defined with a "parameters" block (which translates to a .param statement in the netlist)
Looks like the options isn't provided. How about using scripting instead?
Thanks for the reply FvM. I'm not familiar with scripting, and I couldn't find any entries in the PSpice users guide for "script" or "scripting". Do you have a reference on that?
Scripting isn't supported by PSPICE itself, but you can manipulate design files by an external script interpreter and make it run the analysis.
