PSPICE Propagation delay calculation
Ikh1
Newbie
Hello, I have designed some circuits in Pspice using Orcad Capture. I need to calculate the propagation delays for the same. Are there any commands that can be used? Or do I have to calculate it manually for each circuit by taking points at 50% supply voltage?
I have to find the delay at various temperature and supply voltage intervals. Is manual the only way?
Please review Users Guide, Chater Viewing Results - Measurement Expressions. You'll probably do some calculations with Xat... expressions. Sweeping over temperature and supply can be programmed.
