PSPICE (Orcad family release 9.2 lite edition)
tok47
Full Member level 1
Kuala Lumpur, MALAYSIA
orcad family release 9.2 lite edition
recently, i use pspice capture CIS by this version to simulate some circuit.
I running AC Sweep/ Noise Analysis for a common emitter circuit. Probe that i use is VDB (dB magnitude of voltage).
So, is the output that i get should be gain in dB? And the value can't more than 0 (above x-axis/in the positive part of y-axis)?
Actually, what this probe try to simulate?
thx for help.
If you want to display the gain of your common emitter schematic, in the PROBE windows :
click on Trace\Add Trace... menu.
in the Trace Expression line (bottom of the neew opened window), type :
DB(Vout/Vin), then click OK.
Assuming that Vout is a label you put at the output node of your schematic and Vin is a label you put at the input node of your schematic.
PROBE will then display the gain equal to 20log(Vout/Vin) in db for the frequency range you choose in the AC sweep setup menu.
