Pspice errors: nodes are floating
EmbdASIC
Member level 5
Member level 5
Polar Region, Mars
hi all,
im a real newbie to pspice, im using it through the orcad version 10.
Now as i draw a schematic for analysis and have just two resistors and a power source vdc, gives me errors that dont seem true:
ERROR -- Node N00950 is floating
ERROR -- Node N00885 is floating
ERROR -- Node N00939 is floating
now to me none of these nodes are floating, so whats the problem, plz help
Re: Pspice error
Hello EmbdASIC !!!
I think what you inserted capacitors in the nodes N00950, N00885 and N00939.
You try shorting capacitor by resistor with high resistance (GOms).
Re: Pspice error
What type of "ground" have you used?
As I know from OrCAD 9.2, there are three types of ground in library. You need ground with name 0.
Pspice error
you need the ground named "0"
place >> ground >> source >> 0
Re: Pspice error
yeah place a ground and u should be through with ur problem... i used to have the same prob when i started
