PSpice error: Cannot initialise profile
pjg
Newbie level 2
Newbie level 2
When attempting to create a new PSpice simulation profile in Capture 9.2.3 running on Windows XP Pro, I receive a "Cannot Initialise Profile" message, does anyone know why this problem occurs and a possibe solution.
I also receive a "Failed to Connect to PSpice Simulation Server" message when I attempt to open one of the PSpice example projects in capture.
Any assistance would be gratefully received,
Thanks,
PJG.
pspice cannot initialize profile
Please verify whether your license file is correctly set up.
    pjg
failed to connect to pspice simulation server
Thanks for the reply,
The license file checked out ok so I reloaded the entire package hoping that it may sort out any registry problems etc and that appears to have done the trick.
Regards,
PJG
Are you the member of Administrators?
If not, You cannot create a simulation profile because you do not have right to write the directory ORCAD is installed in.
