Pspice Buck Chopper Simulation
Arif Syazwan
Newbie level 6
Newbie level 6
I have done a buck circuit using Pspice but i have some problem with the Voltage,power and current Output.
By calculation i should get 60V and 4kW for the output
Vo = 60V
Vin = 339.4V
Duty cycle,
T =50us
F = 20k
D= 60/339.4
=0.178
DT = 60/(339.4 ) x 50us
= 8.9us
Output Current,
Iout = Pout/Vout
= = 4000/60
= 66.667A
Resistance,
R =Vout/Iout =60/66.667
= 0.8999 Ω
but in simulation i get:
Average Voutput = 49.4V
Average Power = 2.67kW
Average power:
Average Voltage:
Seem way off from the calculation..
Im try to figure what to do, so,i can get the nearest value with the calculation. I hope someone can help me with my problem.
Unsuitable diode, possibly hidden switch resistance.
1. You didn't think when selecting the components.
2. You didn't use the features of Spice to check yourself where the voltage drop occurs.
I try to find a suitable diode but i did not find one in pspice..
you must also ensure that the reverse-repetitive maximum voltage is greater than the maximum input voltage (VRRM >VINMAX). The diode’s
forward-current specifi cation must meet or exceed the maximum output current (i.e.,IFAV> IOUTMAX).
