jcu85
Newbie
Hello All,
To begin, I am designing a ~3kW phase shifted full bridge design, to take 250VDC to ~1200VDC at ~2.5A. All component selection was based on TI's UCC2895 datasheet.
I am experiencing an oscillation in primary current when running the output of my transformer into a rectification stage. When running the mosfet power stage into a resistive load, of a similar power draw, I am not experiencing any oscillation of current. Likewise, when running the mosfet power stage into the transformer, then directly into a resistive load, there are little to no oscillations. My problem only exists while I am running into the rectification stage.
I have attached a picture of the rectification stage to this post - I have since removed the capacitors parallel to the diodes, since I believe my problem to be related to leakage inductance and capacitance on the secondary. I have additionally attached an excerpt of the power stage, as well as scope shots of the bridge current running into a resistive load and into the rectification stage.
I have read through the "Phase Shift Full Bridge SMPS is massively over-hyped" thread, originally posted by treez. One important thing I noticed, is Easy Peasy's suggestion to incorporate a 1nF across the mosfets in the power stage, which I will work to test tomorrow.
I have seen additional designs in which there is an RCD snubber on the output of the rectifier diodes, before the series inductance. I will have to run simulation to find a design that is appropriate.
Aside from these points, is there anything missing I could try?
Thank you
Thank you
