PSFB Peak and Valley Switching
sabu31
Advanced Member level 1
Dear All,
I am testing a PSFB controlled using UCC28950.
I want to know whether the delay between the Top and Bottom Switches of same leg are correct . I am attaching the waveforms
  • Drain_Source_voltage.pdf
~600 ns dead time must always be > FET turn off time when hot
so lots of margin at room temp I think.
Clean up your trace noise with proper probing, and very short gnds
PWM below
I am getting a spike in input current. Is this correct or there is some timing mismatch in delays. Also what is cause for the notches in the transformer voltages. The schematic is attached showing current measurement point and the devices chosen for measurement.
  • SCHEMATIC_LAYOUT_PSFB.pdf
I am attaching my Primary Side device and QA and Secondary Device QF (synchronous) gating signals. Should The QF be on more than QA or is this sufficiently
Both as long as F-A is always greater than zero at max junction temp to avoid shoot-thru since delays/risetime increase with T.
So there must be safety margin and that means a RD snubber may be needed if you want to clamp V=LdI/dt, yet only at 100% PWM, since this is a tri-level driver. ( or ought to be)
LaTeX Commands Quick-Menu:
