PS3 AV multi - D-sub problem
teges
Newbie level 1
Newbie level 1
Hello!
I made a cable that allows me to connect ps3 to the monitor(Samsung SyncMaster 2243lmx) via av multi -> d-sub.
Cable works but the image is green (as if someone put green screen filter).
I used LM1881N (video sync separator) and i added 220uf capacitor for each line (R,G,B) - the problem still the same.
I plugged a second monitor (Philips 190wv) - problem does not go away, but when i changed settings on ps3 to 1080p
colors shine, green is not very visible, the rest of the color (eg yellow) it's clear, but instead of black is purple.
Red and blue are visible. Overall, it lacks the 'white'. In the console, I set the display to Component / D-Terminal.
Screens: **broken link removed**
Scheme which i used:
and lm1881n:
PS Sorry for my bad english, I hope you understand my text
