Provide customized service for video conversion scheme
jaxlee
Newbie level 1
Newbie level 1
Solution about AHD2.0 converts AV/ VGA/HDMI/ YPBPR
With the development of high definitional camera with analog signal such AHD, TVI and CVI, the traditional AV cameras are replaced. In the past, if a product with rear camera can't support high definition and analog signal, the only way is to change the whole set of terminal equipment. Because it costs a lot, this is a big questionable challenge. However, out solution does solve it! By combining the box of converting AHD2.0 to AV, terminal equipment can accept AHD signal eventually.
Nowadays, there are three solutions about converting AHD or TVI.
1. Connecting with FGPA. It not only has big power dissipation, but also costs more.
2. Using IC from Hisilicon. Perhaps, costing more is not a big deal , but the huge volume may only suit to produce DVD.
3. Using IC from Chipav. It must be a wonderful idea because it is small volume, low cost, and small power dissipation, so this IC (CV2880) is very suitable to produce converters.
This new IC 2880 is ready mass production. If you need any information about this IC, you can just contact with Zhongrong Li
TEl:4155288550
Eamil:jax@chipav.com
