prove of sin(a+b)= sin(a).cos(b) + sin(b).cos(a)
Highlander-SP
Member level 3
Member level 3
vector prove sin(a-b)
What is the main way to prove that sin(a+b)= sin(a).cos(b) + sin(b).cos(a) ?
ps. without euler
you can do it geometrically .By using two right triangles one of angle A and the other of angle B side by side and computing the sin(A +B ) od new TRIANGLE in terms of sine and cosines of A an B angles
You can also find it with a VECTOR approach and a ROTATION and find the MATRIX of such rotation it comes from the fact that ROTATIONS are linear mappings .so they verify :
R(A+ B) = R(A) + R(B) ..This is linear algebra is very simple to demostrate
you can use euler theory I think... with the exp notation...
edit : sorry I didn't saw the euler PS...
you can draw a circle and the proof appears after some purely geometric combinations.
check this page:
it has an applet to demonstrate the proof.
sin(A+B)=sin A cos B + cos A sin B
sin(A-B)=sin A cos B - cos A sin B
cos(A+B)=cos A cos B - sin A sin B
cos(A-B)=cos A cos B + sin A sin B
hi
i suggest you
refer to lithold's book
bye
phongphanp said:
Anybody can tell me an aplication of above relation?
In any number of places. Suppose u wanted to find sin75 using sin45 and sin30.
ps. without euler
:idea: You could use the reverse engineering method.
Start from the RHS and reach teh LSH.
There exist a formula :
2 sinA.cosB =sin(A+B)+sin(A-B)
multiply and divide the RHS by 2.
so you have
½.2.sin(a).cos(b)+½.2.sin(b).cos(a)
½{sin(a+b)+sin(a-b)}+½{sin(b+a)+sin(b-a)}
½{sin(a+b)+sin(a-b)+sin(a+b)-sin(a-b)}
½{sin(a+b)+sin(a+b)}
sin(a+b)
write these in the reverse order and you have the proof. !:D
