Proteus x Mplab Source Code (Assembly)
Dragnovith
Junior Member level 1
Hi, this standard procedure is usually done to work with PIC16F877A in Mplab.
MPLAB
org 0x00   ; reset vector
goto Start  ; after reset start
org 0x04   ; interruption vector
goto Start  ; after interruption start
And in the PROTEUS:
RST code 0x0
    GOTO Start                        ; After reset, start in main function
ORG 4
PGM code
Start
I would like to apply the procedure below (performed in proteus) in mplab.
RST code 0x0
ORG 4
    BTFSC INTCON,1                    ; Check interruption by INT
    GOTO InterrupcionINT                    ; If it is enabled. Interruption by INT
                                    ; It is not activated. Check another interrupt
    BTFSS V_ESTADO_LAVACAR,7            ; Check if the washing machine's status is on
    GOTO DescartarInterrupcao            ; It is not activated. Other interruptions not performed
                                    ; If it is enabled. Compare other interruptions
    BTFSC INTCON,0                    ; Check Interruption by BI
    GOTO InterrupcionRBI                    ; If it is enabled. Interruption by RBI
    GOTO InterrupcionTMR0                ; It is not activated. Interruption by TMR0
    BTFSS PORTB,4                        ; We eliminated the mismatch condition to be able to erase the RBI pin
    nop
    BCF INTCON, RBIF                    ; Erases the interruption by RBI
    BCF INTCON, T0IF                    ; Erases the interruption by TMR0
    RETFIE
PGM code
Start
What was done in mplab
org 0x00   ;vetor de reset
org 0x04
    nop
    RETFIE
    GOTO Start
Start
It doesn't seem to me to be the same thing, what would be the correct way to do this?
Solution
They are all the same thing. After reset or restart, the program counter is loaded with 0x00 and it immediately jumps to the start of the program "Start". The interrupt vector is fixed at 0x04 so the ISR must be at that address, the reset address contains code that jumps over the ISR to where the program execution should start.
Brian.
Brian.
Solution
Brian.
That was it. Thank you again!
