the_dynamo
I have made a circuit in proteus, but i ned a little help in understanding it and making it work. It is a simple 2x seven segment display counter with 2x 555 circuits. I need help controlling the speed it counts. Im not sure if there is a problem with my poor math.
If for example I needed to make my displays count at one count per second, how would I achieve this? I believe it would be by adjusting the R1 and R4 resistor values. I have tried this but can not work out the relationship between them and the timing.
I have hooked up an oscilloscope (image included) and I am not sure what I am looking at. Would I be correct to say that ChA (pin3 on U1) controls the period, and ChB (pin3 on U2) controls the frequency? If this is correct i'm still not sure how this affects the counting and how I would work out my resistor values to achieve a certain speed.
I have included two images, one of my circuit and one of the oscilloscope. Thanks in advance if you can enlighten me of the math so I can adjust my timing circuit. Thats all I need, just a bit of help understanding and/or the equation so I can vary its speed. Let me know if you can do this? Thanks loads guys.
