Firstly you'll have to upgrade to the latest version of proteus, to have a clear idea whether labcenter have included the device in proteus or not..
If it is not available there, then you 'll have to create the device yourself for that I would suggest to go through proteus help files.
BTW:
I am pretty impressed with the schematics you have drawn and I am more interested in knowing the application that you have used to draw attached schematics..
thank u sir,plz guide me how to create a new IC in proteus???
Go to ISIS Help, under "library facilities", check the section called "device libraries".
BTW you never mentioned the software that you have used to draw the schematics that you have posted??
Probably from the tools menu you had had selected delete all option, that is why your components are all deleted.
Once you open your design file, take the mouse pointer to the left side of the screen where there are icons, click on the arrow icon on the top and hopefully your design file should be alright now.
