pjthedewg
Newbie level 2
Proteus presenting Stack underflow[STKUNF set, zero returned] when compiled
The schematic is attached. The code, using c and the xc8 compiler for the pic18f46k22. I'm making a traffic light controller for 4 different lights. i set the delay to just 100ms temporarily. i'll fix that later and set it to loop so i get 5-15 second delay.
* File: main.c
* Author: IBRAHIM LABS
* EMAIL: Ibrahimlabs@gmail.com
* Website: http://www.ibrahimlabs.com/
* Created on March 16, 2014, 8:05 PM
//#include <pic18f46k22>
#include <xc.h>
#define _XTAL_FREQ 1000000UL // 10MHz
// CONFIG
// CONFIG1H
#pragma config FOSC = INTIO7 // Oscillator Selection bits (Internal oscillator block, CLKOUT function on OSC2)
#pragma config PLLCFG = OFF // 4X PLL Enable (Oscillator used directly)
#pragma config PRICLKEN = OFF // Primary clock enable bit (Primary clock can be disabled by software)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power-up Timer Enable bit (Power up timer disabled)
#pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 190 // Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer Enable bits (Watch dog timer is always disabled. SWDTEN has no effect.)
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC1 // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<5:0> pins are configured as analog input channels on Reset)
#pragma config CCP3MX = PORTB5 // P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
#pragma config HFOFST = ON // HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
#pragma config T3CMX = PORTC0 // Timer3 Clock input mux bit (T3CKI is on RC0)
#pragma config P2BMX = PORTD2 // ECCP2 B output mux bit (P2B is on RD2)
#pragma config MCLRE = EXTMCLR // MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection Block 0 (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF // Code Protection Block 1 (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF // Code Protection Block 2 (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF // Code Protection Block 3 (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF // Write Protection Block 3 (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
#define G1 PORTBbits.RB0
#define Y1 PORTBbits.RB1
#define R1 PORTBbits.RB2
#define G2 PORTBbits.RB3
#define Y2 PORTBbits.RB4
#define R2 PORTBbits.RB5
#define G3 PORTCbits.RC0
#define Y3 PORTCbits.RC1
#define R3 PORTCbits.RC2
#define G4 PORTCbits.RC3
#define Y4 PORTCbits.RC4
#define R4 PORTCbits.RC5
#define start PORTAbits.RA4
/*void delay_100ms(unsigned char n)
int main() {
while(1)
G1 = 1;
R2 = 1;
R3 = 1;
R4 = 1;
G2, G3, G4, Y1, Y2, Y3, Y4, R1 = 0;
__delay_ms(100);
Y1 = 1;
Y2 = 1;
R3 = 1;
R4 = 1;
G2, G3, G4, G1, R2, Y3, Y4, R1 = 0;
__delay_ms(100);
G2 = 1;
R1 = 1;
R3 = 1;
R4 = 1;
G1, G3, G4, Y1, Y2, Y3, Y4, R2 = 0;
__delay_ms(100);
Y3 = 1;
Y2 = 1;
R1 = 1;
R4 = 1;
G2, G3, G4, G1, Y1, R3, Y4, R2 = 0;
__delay_ms(100);
G3 = 1;
R2 = 1;
R1 = 1;
R4 = 1;
G2, G1, G4, Y1, Y2, Y3, Y4, R3 = 0;
__delay_ms(100);
Y3 = 1;
Y4 = 1;
R1 = 1;
R2 = 1;
G2, G3, G4, G1, Y2, Y1, R3, R4 = 0;
__delay_ms(100);
G4 = 1;
R2 = 1;
R3 = 1;
R1 = 1;
G2, G3, G1, Y1, Y2, Y3, Y4, R4 = 0;
__delay_ms(100);
Y1 = 1;
Y4 = 1;
R3 = 1;
R2 = 1;
G2, G3, G4, G1, Y2, Y3, R4, R1 = 0;
__delay_ms(100);
return 0;
