Proteus PCB and Netlist mismatch
remr96
Newbie level 5
Newbie level 5
Hi Friends,
Good Day to you.
Am using Proteus 7.8. Recently i had a issue in a file which was on hold for a long time and the layout was also 70% finished . I received a latest file with many parts removed and new parts added in that schematic. after assigning the components imported Netlist to the layout. it was working well and the layout was 90% finished. but when at evening when i try to open the file it doesn’t open. my whole day work was wasted. expect the old file all new netlisted files r not opening. this issue is only with the Layout file now with the schematic.
i checked with the other different job files , all other files are running well.am fully lost.
can anyone help me to solve the issue.
symptoms with the files are:
1.) file not opening .
Message displayed:
" Internal Exception : Accesses violation in module 'ARES.EXE' [004552D0].
A Serious error has occurred and ARES Professional is in an unstable state.
Click ABORT to Quit immediately , or OK to if you want to save your work first .
Do not assume that the saved copy will be loadable."
2.) even its opened working layers are disabled.
3.) After placing a new component and saved. the file cannot be reopened. same message will displayed as i said in point(1).
usually when a file is opened we can see the file name at the top left corner of the software , but in this particular file the file name is also not displayed at the corner.
Kindly help me to solve this issue.
