Proteus+Hi Tech PICC combination
pro_ind
Junior Member level 1
proteus hitech c
Hi all,
I just started to use Proteus 5. I want to know that whether we can
use Hi-Tech PIC C coding with Proteus stimulation. I use Hi tech PICC in
for my work... Please help.......
Thanx......
pro_ind
hi-tech picc serial number
You can use this combination very well.
There are 2 ways:
1. you can use the hex file produced by picc (you'll not have source level debugging)
2. use the cod file. This is realy nice.
Success
As a general rule you can use hex files generated from any language or assembler, as long as the processor model is available. I use Ke=l, CCS and bascom without any problems.
I use both of them and simply, I'm happy! I think hitech c compiler is the best but if you want to use other compilers or interpreters you should use hex files.
Regards.
Thanx
Hi All,
Thanx for the help...
Yes after using hex file i suceed in geting correct result...Thanks a lot..
regards
pro_ind
Dont use the hex file, use the COD fiel, because with it you can debug the C source code!
Pay attention in one important point, that is, if you use only one pin like: RB0=!RB0
Some time Proteus dont work well (pin stay allways at one), to make that you must use: PORTB=(PORTB&0xfe)|(!RB0)
Hope helps,
NeuralC
to NeuralC :
I think
RB0=!RB0 is not correct because ! is for booleans
instead you should try
RB0=~RB0
aProgrammer: !RB0 in Hitech Picc work (try it directly on a PIC), and the problem it's not on the C code. Here the question are if you use the all PORT or use only one PIN. If you analyse the assembler code generated using !RB0 or ~RB0, they are the same...
And in C language the boolean type does not exist!
NeuralC
Pic c
I have downloaded pic c 8.01pl3 from htsoft and used a keygen from astalavista.box.sk but it says "compiler not installed correctly". Please Help. :(
Try put Serial Number with only 5 digit
NeuralC
attn.
if you use serial gen. fss or a old serial which produced by fss u can use only picc v8.00 pl3 picc18 v8.12 pl1. may be this is the reason u can not use picc.
p.s. if you find these old version install sets pls. tell me too.
