PROTEUS EXTRA LIB AND MODLES FINAL RELEASE
Fragrance
East Of Earth
proteus extra lib
HI, ALL
Please find the extar library and modles for proteus this is the final release
of last upload
regards
Fragrance
proteus libs
Can you list the inside models ?
it avoid we download the same thing again .
proteus isis e are dowload versao 2001
Hi Nobody
As i uploaded the last lib it contain the last file lib also but lot of new lib and modle are in this zip file downloaded from varies site
regards
Fragrance
proteus library microphone
Thanks Fragrance.
/ Warning #1 - No thanks at elektroda! Read forum rules before posting! /
proteus extra library
Hi Fragrance,
is there any project(.dsn) file for d*s162*1
my project file ran without problem but i cant take temp from it.
Regards.
proteus back into an old version indir
here is the ds and isc spy chips dlls
older versions but working as i think the only change TeHB added was the licence changed but seems new version crashes
here are working ones
hope the dosnt mind let me know if you do andrew and ill move this
undongle.newmail.ru.
Hi All!
Ok, I'll fix it.
My new site address is **broken link removed**
microphone model proteus
Hi
THEb done the great job last night and he has fixed the problem with it's all model I am Thank full for his copration regarding bugs fixing nice work THEb
regards
Fragrance
proteus speaker.dll
Hi all
i want to know how i can make"by my Self " new modle for protus :cry:
thanks
yours
S 8O KRAT
proteus final version
Find The post by TEHb You will find the Method how to make models
if you want to make the dll model then read the TEHb post if you wnat to made just simple model you can just made a MDF file of your device by
selecting option model compiler
Fragrance
download extra proteus library
Here is the bug fixed model of TEHb
Fragrance
isis external input proteus
Hi all!
It is better to download latest versions of my models from my site - undongle.newmail.ru
Andrew.
final version proteus
TEHb said:
Hi all!
Andrew.
Hi my friend why this uploaded your model have still problem with them
they cannot simulate
the up was fixed one
regards
fragrance
proteus extras
Hi all
the new lib not work and this message "No model specified"
if any one have modle for microphone send it
thanks
S 8O KRAT
isis proteus libs
there is NO model for any form of audio input to isis
OK !!!!!
this requires a DLL
even with a dll its not as simple as you may think too run realtime audio into a latency {event} driven simulator
that dosnt run in realtime at the same time frame as the audio
so some sort of sim lock would be needed that triggers the call to the routine that deals with talking to the soundcard via mmsystem.dll
and again this dll would need to be called probably
elsewhere in isis exe perhaps???
to set up the dll and send the peramiters {volume balance etc} and also fill and empty about a 10 mb buffer
so not ! realy that pheasable
i hope this answers your question
instead use the audio genorator and some form of modulator {A diode or two and another genorator springs to mind}
?do you realy need audio in ????
why ??
download proteus extra library
hi MONKEY this is good idea
but i mean by internal input for microphone in the simulation not external input
OK!!!
i want to generate sound by using signal generator and speaker and receive it by using microphone and then amplification receive signal
this is first stage from my proiect
so i want model for microphone
S 8O KRAT
