Proteus close continously
ep.hobbyiest
Full Member level 4
Full Member level 4
I am using proteus and pic controller. i am facing problem of proteus which closes continously.
what could be the problem.
Does it happen when the microcontroller is connected to the PC,or even without the microcontroller being connected..?
no i had not connect the controller to the pc. i have make circuit on proteus and simulate it.
Which version of proteus are you using?
Can you post the schematic you're simulating here so I can try it out?
Allen
Mostly Proteus 8.0 SP1 version closes after 10-15 minute.
I also have the same problem in all simulations.
I am still using proteus 7.80 and it works fine. May be those who use version 8 can help you.
ALlen
I was also having the same problem with Proteus 8, so i switched back to 7.10 .. :(
also if i install usb drivers from proteus then proteus block all physical usb port of PC...8-O
