proteus and the print out signal
sokrat
Full Member level 5
Full Member level 5
EGYPT
HI all
i want to know how i can print the out signal from OSILLIOSCOPE in proteus :?:
thanks
S 8O KRAT
Press <Print Screen>, paste it in Paintbrush and print! :)
Hi! I wonder if it is the only way to print the graph in proteus!
Thanks !
Hi Sokrat, you can print a graph instead of the scope by simply
open a graph analog or digital or any other from the graph menu
add voltage probes or current probes to the test points after highlight them
and drag them into the graph hit the space button on your keyboard.
After the simulation is done you can print the graph easily.
Tornado
