T
treez
Hello,
I am trying to use proteus for schematic drawing and creating (drawing) schematic symbols into a library.
Does anyone know of a tutorial or youtube video which explains how to draw a schematic symbol and then save it in the library? I seem to find that Proteus does not have a schematic symbol editor, but instead you just seem to start a schematic and then draw your intended schematic symbol in there(?)
Also, when I am drawing a schematic symbol, I am not able to change the grid on the screen. Do you know how?
Also, I have access to the schematic symbols that come with Proteus. Sometimes I wish to copy these but make a new schematic symbol out of them. Do you know how to do this?
Another point is that when you pull out a pin for a schematic symbol, it doesn’t seem possible to rotate it as you are dragging it over to the schematic symbol. Do you know how to do this?
All of these things are as simple as “falling out of bed” in the Eagle PCB program. Why is Proteus much less obvious? Proteus seems to me like a PCB/Schematic program made by sopftware engineers…..whereas Eagle is much more intuitive because its made by (German) Electronics Engineers.
Ive done schematic symbol creation in eagle and altium and its easy, and there are loads of tuorials in it in eagle (less so for altium). But proteus, not only is it very hard to understand, but there are not the needed tutorials available for it. Do you agree?
Also, i hear that Proteus only does Gerber files in imperial. Is this a problem for the PCB makers?....ive always done it in metric using Eagle.
