Paul98
Member level 5
Hi there,
i am trying to create a component with related spice data but i have some difficulty in doing it. I download the component from the componentsearchengine in order to already have the base with the footprint and the symbol then click on make device to modify it by entering the location of the TXT file containing the .MODEL data.
I conclude the modification of the component with the addition of the spice instructions and text the simulation but it does not work. Obtained:
No model specified for Q1. [Q1]
Simulation FAILED due to partition analysis error(s).
Alternatively I tried to insert spice data also via "edit properties" and "edit all properties ad text" using * SCRIPT SPICE and * ENDSCRIPT at the beginning and end of spice instructions but without success.
The spice data contained in the file are correct they work if I use a generic NPN as a model but in this way I do not have the footprint for the PCB (in case I wanted to).
Thanks
Thanks
