bubblecarps
Newbie
Hello, I'm about to simulate a project and I would just like to ask on how could I change the current rating (I) of my AC sine voltage supply? Thank you to those who would respond.
Unless the model has specific parameters that can be changed, a simulator calculates with ideal models of components.
Don't know about Proteus but could there be an alert you can set for a supply, letting you know if Ampere level exceeds a certain amount?
Hi Brian. Thank you for your response. I saw your point, however, my concern is, in my schematic, I have to incorporate a step-down current transformer in order to show that the AC supply provides high current rating.The 10A rating is just the maximum your simulated supply should be able to deliver, it isn't what it actually provides. The rest of your schematic is what decides how much current is drawn from it and your simulation result will probably show the expected figure. I'm not sure whether Proteus raises an alarm if the current is exceeded but it should be able to tell you how much and the profile it follows under different load conditions.
Brian.
