PROTEUS 8 PROFESSIONAL: CONTROLLER RECEIVED COMMAND WHILST BUSY.
magicxrps
Newbie
Newbie level 3
Hello, the nature of my work is to simulate an automatic power factor correction system using Arduino Nano in Proteus 8 Professional in which my program is coded in Arduino IDE. However, upon simulating the circuit, the errors "Controller received command whilst busy", "[HD44780] Controller received data whilst busy", and "Simulation is not running in real time due to excessive CPU load" are appearing. How could I mitigate these issues?
[CODE=cpp]CODE:
#include <math.h>
#include <LiquidCrystal.h>
LiquidCrystal LCD(13, 12, 11, 10, 9, 8);
float Power_Factor, load_voltage, load_current, real_power, angle_rad, total_capacitance, Q_reqd, New_PF, I_secondary;
float peak_voltage = 0;
float peak_current = 0;
int f = 60;
float vSensor = A0;
float iSensor = A1;
unsigned long time_diff;
const int XOR = 0;
const int capacitor_pin[] = {1, 2, 3, 4, 5, 6, 7};
void setup() {
  LCD.begin(20, 4);
  LCD.setCursor(0,0);
  LCD.print(F("AUTOMATIC"));
  LCD.setCursor(1,0);
  LCD.print(F("POWER FACTOR"));
  LCD.setCursor(2,0);
  LCD.print(F("CORRECTION"));
  LCD.setCursor(3,0);
  LCD.print(F("SYSTEM"));
  unsigned long initialization_time = millis();
  while (millis() - initialization_time < 2000){
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(0, INPUT);
  for (int i = 0; i < 7; i++) {
    pinMode(capacitor_pin[i], OUTPUT);
    digitalWrite(capacitor_pin[i], LOW);
  time_diff = 0;
void CapacitorCombinations(int j) {
  static unsigned long CapComb_time = 0;
  if(millis() - CapComb_time >= 450){
    CapComb_time = millis();
    String base_2 = String(j, BIN);
    while (base_2.length() < 7) {
      base_2 = "0" + base_2;
    for (int k = 0; k < 7; k++){
      if (base_2.charAt(k) == '1') {
        digitalWrite(capacitor_pin[k], HIGH);
      else {
      digitalWrite(capacitor_pin[k], LOW);
void ComputePF() {
  static unsigned long PF_time = 0;
  if(millis() - PF_time >= 300){
    PF_time = millis();
    time_diff = (pulseIn(XOR, HIGH, 1000000L))/1000000;
    angle_rad = 2*PI*f*time_diff;
    Power_Factor = cos(angle_rad);
float ReqdCapacitance(float PF, float V, float I) {
  static unsigned long ReqdCap_time = 0;
  if(millis() - ReqdCap_time >= 350){
    ReqdCap_time = millis();
    float C_reqd, X_c, P;
    C_reqd = 0;
    P = V*I*PF;
    Q_reqd = P*(tan(PF)-tan(0.96));
    X_c = (V*V)/Q_reqd;
    C_reqd = 1/(2*PI*f*X_c);
  return C_reqd;
float CapacitorActivation(float Cap_Reqd) {
  static unsigned long ActivateCap_time = 0;
  if(millis() - ActivateCap_time >= 400){
    ActivateCap_time = millis();
    float capacitor_bank[7] = {1e-6, 2e-6, 4e-6, 8e-6, 16e-6, 32e-6, 64e-6};
    int cap_combination = 0;
    total_capacitance = 0;
    for (int l = 0; l < 128; l++){
      for (int m = 0; m < 7; m++){
        if (l & (1 << m)){
          total_capacitance += capacitor_bank[m];
      if (total_capacitance >= Cap_Reqd){
        cap_combination = l;
        break;
    return cap_combination;
float CorrectedPF(float PF, float V, float I) {
  static unsigned long CorrectedPF_time = 0;
  if(millis() - CorrectedPF_time >= 500){
    CorrectedPF_time = millis();
    float P, C_reactance, C_reactive_pow, L_reactive_pow, Q_new, theta_new;
    P = V*I*PF;
    C_reactance = 1/(2*PI*f*total_capacitance);
    C_reactive_pow = (V*V)/C_reactance;
    L_reactive_pow = (V*I)*sin(acos(PF));
    Q_new = L_reactive_pow - C_reactive_pow;
    theta_new = atan(Q_new/P);
    New_PF = cos(theta_new);
    return New_PF;
void DisplayNoLoad()  {
  static unsigned long NoLoad_time = 0;
  if(millis() - NoLoad_time >= 100){
    NoLoad_time = millis();
    LCD.clear();
    LCD.setCursor(1,0);
    LCD.print(F("NO LOAD"));
    LCD.setCursor(2,0);
    LCD.print(F("CONNECTED"));
void DisplayInitialParameters() {
  static unsigned long InitialParameters_time = 0;
  if(millis() - InitialParameters_time >= 300){
    InitialParameters_time = millis();
    LCD.clear();
    LCD.setCursor(0,0);
    LCD.print(F("PF: "));
    LCD.print(Power_Factor, 2);
    LCD.setCursor(1,0);
    LCD.print(F("VOLTAGE: "));
    LCD.print(load_voltage);
    LCD.print(F("V"));
    LCD.setCursor(2,0);
    LCD.print(F("CURRENT: "));
    LCD.print(load_current, 2);
    LCD.print(F("A"));
    LCD.setCursor(3,0);
    LCD.print(F("POWER: "));
    LCD.print(real_power);
    LCD.print(F("W"));
void DisplayCorrectedPF() {
  static unsigned long FinalParameters_time = 0;
  if(millis() - FinalParameters_time >= 600){
    FinalParameters_time = millis();
    LCD.clear();
    LCD.setCursor(0,0);
    LCD.print(F("Required Qc: "));
    LCD.print(Q_reqd, 2);
    LCD.print(F("VAR"));
    LCD.setCursor(1,0);
    LCD.print(F("Required C: "));
    LCD.print(total_capacitance, 2);
    LCD.print(F("C"));
    LCD.setCursor(2,0);
    LCD.print(F("Corrected PF: "));
    LCD.print(New_PF, 2);
void DisplayNoCorrectionNeeded()  {
  static unsigned long NoCorrection_time = 0;
  if(millis() - NoCorrection_time >= 700){
    NoCorrection_time = millis();
    LCD.clear();
    LCD.setCursor(0,6);
    LCD.print(F("PF: "));;
    LCD.setCursor(1,9);
    LCD.print(F("NO"));
    LCD.setCursor(2,5);
    LCD.setCursor(3,7);
    LCD.print(F("NEEDED"));
float ReadVoltage()  {
  static unsigned long peak_voltage_time = 0;
  if(millis() - peak_voltage_time >= 100){
    peak_voltage = analogRead(A0)*(5.0/1023.0);
    if(peak_voltage < 0.0 || peak_voltage > 5.0){
      return;
    peak_voltage_time = millis();
    return peak_voltage;
  return -1.0;
float ReadCurrent()  {
  static unsigned long peak_current_time = 0;
  if(millis() - peak_current_time >= 100){
    peak_current = analogRead(A1)*(5.0/1023.0);
    if(peak_current < 0.0 || peak_current > 5.0){
      return;
    peak_current_time = millis();
    return peak_current;
  return -1.0;
void ComputeLoadCurrent() {
  static unsigned long LoadCurrent_time = 0;
  if(millis() - LoadCurrent_time >= 200){
    LoadCurrent_time = millis();
    float Vrms_current, V_Rburden;
    Vrms_current = peak_current/sqrt(2);
    V_Rburden = Vrms_current + 1.4;
    I_secondary = V_Rburden/5.0;
    load_current = I_secondary*(20/1);
void ComputeLoadVoltage() {
  static unsigned long LoadVoltage_time = 0;
  if(millis() - LoadVoltage_time >= 200){
    LoadVoltage_time = millis();
    float Vrms_voltage, V_drop;
    Vrms_voltage = peak_voltage/sqrt(2.0);
    V_drop = 1.4 + (I_secondary)*1000.0;
    load_voltage = (Vrms_voltage + V_drop)*(230.0/5.0);
void ComputeRealPower() {
  static unsigned long RealPower_time = 0;
  if(millis() - RealPower_time >= 250){
    RealPower_time = millis();
    real_power = load_voltage*load_current*Power_Factor;
void loop() {
  ComputeLoadCurrent();
  delay(50);
  ComputeLoadVoltage();
  delay(50);
  if(load_current < 0.0){
    DisplayNoLoad();
    delay(50);
  else if(load_current > 0.0){
    ComputePF();
    delay(50);
    ComputeRealPower();
    delay(50);
    DisplayInitialParameters();
    delay(50);
    if (Power_Factor < 0.96){
      float Required_Capacitance = ReqdCapacitance(Power_Factor, load_voltage, load_current);
      delay(50);
      int Activate_Capacitor = CapacitorActivation(Required_Capacitance);
      delay(50);
      CapacitorCombinations(Activate_Capacitor);
      delay(50);
      CorrectedPF(Power_Factor, load_voltage, load_current);
      delay(50);
      DisplayCorrectedPF();
      delay(50);
    else {
      DisplayNoCorrectionNeeded();
      delay(50);
[/CODE]
Any help would be appreciated!
Attached are the dialog box of the issues and my circuitry.
Hello
The error means that your display is receiving a new command while executing the current one. I think this is due to timing issue between the commands send to the HD44780 or due to the simulation and your project might work fine in real world.
