Proteus 8 multi source files
hirenn
Full Member level 1
Full Member level 1
hi Everyone,
i'm using proteus 8
i want to add a keypad and lcd source code in two different files instead of write full code in single main.c file, in proteus
how can i do it
i tried header file , but when i run project ,there is no output in simulation
Right-click in the projects window allows adding files
Thanks for reply
i add .c files using right click but ,it can't link between two files
How do you know it didn't link? Was there an error where the routine in the second file could not be found? If you add a file that has routines in it that are not called, they will not be compiled and linked (at least that's the way my compiler works).
