Proteus 8.16 IR2101 timestep too small error
LeDuy
Newbie
Newbie level 1
Hello, I'm new to Proteus. I am trying to simulate this ir2101 bootstrapping circuit, yet I keep getting these error:
[SPICE] transient GMIN stepping at time=1.66141e-008 @0.000000017s
[SPICE] TRAN: Timestep too small; timestep = 1.25e-019: trouble with node #00007. @0.000000017s
Please help me figure out what went wrong, I would be very thankful
  • Sample.rar
The driver model is probably a behavioral with too much idealness
and that's often the root of timestep errors - something is moving
too fast for the max timestep you called out, the engine "gets out
over its skis" by missing some edge that mattered and can't back-
step the timestep to get out of the hole.
Some simulators apply "special methods" keying on pulse source
events, to get this under control. Some do not, and some fail to do
the same to other source-types (like vpulse and vpwl maybe, but
not a behavioral source or switches, etc.).
I have seen more than a couple people on the ngspice forum with
what looks like the same problem. You might look for alternate
driver models made by people with a better clue / quality control.
Or make one yourself out of stuff that solves cleaner.
The biggest problems with those power switching circuits are:
* PCB layout
* power supply decoupling
Both are not existent in your simulation. So your simulation most probalbly with show good results. But this does by far not mean that your real circuit works the same way.
Klaus
LaTeX Commands Quick-Menu:
