Proteus 6.2 SP4 code size limitation?
kabron
Newbie level 6
Newbie level 6
Hi, all!
Testing the example AT89C2051_TEMP I've got a message from DSIM:
[U2] Loading HEX file 'Objects\THERM.hex'.
[U2] Read total of 1766 bytes from file 'Objects\THERM.hex'.
ERROR: [U2] Program length exceeds limit of 1024 bytes
[DSIM] BOOT Error.
Real Time Simulation failed to start
Real Time Simulation FAILED
Does it mean that there is a code size limit in simulator or it's the result of the c*r*ack application.
Thanks in advance
Hi Kabron, probably your code has exceed the memory size of that MCU.
Regards
Regards
No, I've tested with 89C51 also with the same result. It seems to me TEHb is right.
Also, hacked copies of the 6.2 SP4 have random payloads...this may be one of them.
