LechU
Member level 2
When I exit Protel 99 SE SP6 ( Full version NOT eval ) using File/Exit I can hear Error Beep, but when I exit using close window "X" everything is OK. What is going on ?
Jayson said:I'm not sure if the OS is an issue other than that it won't installed under Windows ME.
I've never had problems with P*otel 99SE running under Windows 2000 SP2 or SP3. I've used it under Windows XP SP1 and no problems. If it ever shows an error you can always save your work then restart the program and continue.
- Jayson
