yefj
Advanced Member level 5
Hello i am using the following OPAMP in my circuit.
I know i need to put reverse biased diodes to protect my OPAMP.
How do i know what diode exactly can be used in my case?
Also in forward biased the diode has 0.7 voltage drop over it so i should use 5.7V in my power supply to have exactly 5 V on the opamp?
Thanks.
https://www.analog.com/media/en/technical-documentation/data-sheets/AD8031_8032.pdf
Thanks.
