hemnath
Advanced Member level 3
![Advanced Member level 3](/styles/images/ranks/glevel3.gif)
Input will be either Battery: 9V DC or 24V DC.
Output: 3.3V DC
For battery operation, It has ON/OFF circuit. When the button is pressed, Transistor will provide supply to the Regulator. Again if the button pressed, it will power OFF. It also has a option that, when the signal from the Micro controller is applied, it will power OFF.
Please check the attached circuit.
Does this circuit has Overvoltage, Overcurrent, Short circuit, Reverse battery protection, EMC, etc?Please help
Output: 3.3V DC
