kkdelabaca
Full Member level 2
Hello,
Time ago I designed one circuit that can close one contact Normal Open using the protocol RS485. The board has worked very well but now I have problems with an inductive load (coil of other relay) of 110Vdc from one battery. The problem is that in some operations the contact Normal Open is short (the relay is broken).
In the photo you can see the image of the simplifier schematic:
The caracteristics of the contact of the reed relay:
Now I am thinking about using a transil to put it in parallel with the contact NormalOpen, but I have never used a transil. What type of transil you recommend? The Bidirectional Transil solve my problem? The reference BZW04-128B (bidirectional transil) with one Vbr = 143V is Ok for my design? https://www.st.com/stonline/products/literature/ds/2971/bzw04.pdf
The datasheet of the reed relay: **broken link removed**
Thanks!!
Thanks!!
