mnmoh5
Newbie level 5
proportional with sm6135
Normally, for RC control car once you press a trigger to make the car go forward, the trigger causes a pair of electrical contacts to touch, completing a circuit connected to a specific pin of an integrated circuit (IC).
The completed circuit causes the transmitter to transmit a set sequence of electrical pulses.Each sequence contains a short group of synchronization pulses, followed by the pulse sequence.
For our example, the pulse sequence is 16 pulses (forward), which means that the IC sends positive current to the motor running the wheels. If the next pulse sequence were 40 pulses (reverse), the IC would invert the current to the same motor to make it spin in the opposite direction.
However, the speed of the car is restricted to only one constant speed. what i'm trying to design is, the speed of the car will varry proportionally to how hard you press the trigger. Can someone help me in terms of how i'm going to do it and what are the recommeded components for this particular design
