BHARGAVSHANKHALPARA
Junior Member level 3
- Joined
- May 6, 2010
- Messages
- 27
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- GUJARAT INDIA
- Activity points
- 1,592
Hello everyone...
i need some help for my project. actually i made up automatic link changer system.
now my problem is...
in my project i used stepper motor for accurate sliding movement. so for reach and stop at some fixed position is required. for that i have used TCRT5000 (REFLECTIVE OPTICAL SENSOR) datasheet of that can be download from here
https://tinyurl.com/lxpn4gb
problem with this sensor is its not giving accurate position all the time. in my case aluminum surface as a reflective surface so i think due to oxidation process surface property will change with time and due to that i can't obtain accurate position. so i stick mirror at reflective surface but due to that also i can't obtain accurate position.
so i cant understand what is actually going on...?
please suggest me other method of accurate positioning(without any touching physically like limit switch).
