[SOLVED] project in distress..
 unsigned int LastTemp
defines LastTemp variable as unsigned int. So, you cannot store values less than 0 in it. In
 signed int LastTemp
you can store negative values. For range of values for different data types see c18 manual.
Have you tested the LCD code you are using before? Does it work?
i took a look at the C18 Manual..
do you think we can use
#include <capture.h>
or perhaps use
putcUSART
To use putcUSART you have to use OpenUSART() function to start serial communication. Then if you use putcUSART it will print on Virtual Terminal. If you have any other project with LCD code working then post it.
First attached file is Voltage Test.rar.. using ADC..
Second Attached file is my original file , i using the lib original xlcd.h file
i got this error . no matter how i solve also cannot solve ...
Error - could not find definition of symbol 'DelayFor18TCY' in file 'busyxlcd.o'.
  • Voltage Test.rar
  • Rewritten Program.rar
Voltage Test.rar is the one that is displaying strings...
Both are using PIC18F4520 and are using internal osc
#include<p18f4520.h>
#include "picdem2lcd.h"
#include<i2c.h>
#include<delays.h>
#include <stdio.h>
#pragma config OSC = INTIO67
#pragma config WDT = OFF    //Turn off watchdog timer
#pragma config LVP = OFF    //Turn off low voltage program
#pragma config DEBUG = OFF  //Turn off debug mode
void initLCD(void);
//Start Of Main Function//
void main()
	unsigned int LastTemp = 0;
	TRISB = 0x00;
	PORTB = 0x00;
	TRISD = 0x00;
	PORTD = 0x00;
	SSPSTAT = 0x80; //Disable SMBus & Slew Rate Control
	SSPCON1 = 0x28; //Enable MSSP Master
	SSPADD = 19; //Internal Crystal 8MHz, Standard Mode for I2C 100kHz : Fosc/4*(SSPADD+1)
	SSPCON2 = 0x00; //Clear MSSP Conrol Bits
	while(1)
		IdleI2C(); // ensure module is idle
		StartI2C(); // initiate START condition
		while ( SSPCON2bits.SEN ); // wait until start condition is over
		Delay10TCYx(10);
		WriteI2C( 0b10011010 ); // Send TC74 address (Write; LSB=0 10011010)
		WriteI2C( 0 ); // Select Temperature Register
		RestartI2C(); // generate I2C bus restart condition
		while ( SSPCON2bits.RSEN ); // wait until re-start condition is over
		WriteI2C( 0b10011011); // Send TC74 address (Read; LSB=1  10011011)
		ReadI2C(); // read in the temp
		NotAckI2C(); // send not ACK condition
		while ( SSPCON2bits.ACKEN ); // wait until ACK sequence is over
		StopI2C(); // send STOP condition
		while ( SSPCON2bits.PEN ); // wait until stop condition is over
		LastTemp = SSPBUF; // LastTemp is a Global unsigned char
		initLCD();
		putrsLCD((const far rom char * ) "Hello");
void initLCD(void)
	putrsLCD((const far rom char*)"Initializing LCD...");
	TRISD = 0x00;       //Set port D as outputs initially for LCD
	PORTDbits.RD7 = 1;  //Power On LCD
	OpenXLCD(FOUR_BIT & LINES_5X7);
	while(BusyXLCD());
	WriteCmdXLCD(DON & CURSOR_OFF & BLINK_OFF);
	printf((const far rom char*)"done.\r\n");
i followed the same method as i did before but it still couldnt display
See this simulation video. It is displaying and i2c is working but the display is moving. You are not getting the display because you have not called initLCD() before main() function.
  • i2c.rar
Ok. I got the I2C value displayed. See it shows 27 for 27 degrees. We have to stop the moving. Don't worry we will fix it. No not because of the while loop.
  • i2c v2.rar
ic... i remember when i was doing C++ program.
there was a function call leave a line
printf("/n");
or is it /r . i am not very sure of it already
It is printf("\r\n");
Edit: See it is working.
  • Temp(Redo Version) v2.rar
  • Temp(Redo Version) v4.rar
jayanth, if i were to draw a flowchart for my temperature program, how am i going to do it ?
