Bukitoo
Full Member level 2
![Full Member level 2](/styles/images/ranks/elevel2.gif)
Hi! I want to implement a Application that communicates with a embedded system over MODBUS protocol (over serial line). The specification says that (in RTU mode) the timout between characters mst be 3.5 times one character. That time, at somes boudrates, could be less than 1 ms. How can I make a timer with that resoultion use window OS? Is that possible ?
Thanks In advance
Thanks In advance
