Programming concept for a port
RenesasT
Full Member level 2
Full Member level 2
Hello All,
After long time, have a great day all.
I need your help. All suggestion would be greatful for me.
I am using renesas controller, I am taking data in Port lets say port 1 which is of 8 bits,
I am taking status of 3 sensors , which could be either high or low. i.e 0 or 1.
The sensors A, B, C are connected to port 1.0, 1.1,1.2 respectively.
I am reading port in 8 bit variable as sensor.
I am writing below program
sensor=P1;
Its like P1.7P1.6P1.5P1.4P1.3P1.2P1.1P1.0
It is working. Now thing is that. Now I need like P1.7P1.6P1.5P1.4P1.3P1.1P1.0P1.2 in the sensor.
What to write for that?
suppose Port 1=0x01 (00000001) , then I need sensor value as 0x02(00000010).
If Port 1=0x06(00000110), then I need sensor value as 0x05 (00000101).
Please help me.
...I am reading port in 8 bit variable as sensor.
sensor=P1;
Please help me.
already sensor=P1;
you want it as 0x02.
It is an input port.
You have not described what you want ?
I really don´t know what you need.
The sensors are on bit 0, 1 and 2.
So at first I´d mask the three bits by ANDing port value with 0b0000 0111.
Then the result can only be 0...7
binary: 000, 001, 010, 011, 100, 101, 110, 111
Now you could do a switch/case processing.
Or use a table with 8 entries.
Klaus
sensor=P1;
From what I understand, you just want bit 0, 1 and 2 shuffled around?
Of course you could shift around the resulting bits, but if there is no simple arithmetic to convert your port value to your expected signal value, I would just use a table to translate the lower 3 bits:
uint8_t table[] = { 0, 2, 4, 6, 1, 3, 5, 7 };
port = P1;
sensor = (port & ~7) | table[port & 7];
You'll need bit ops in microcontroller coding regularly. Get accustomed with them.
