ramyadhadidi
Junior Member level 1
Programming hardware interrupts
I'm wirting a program that needs UART chip on PC. I want to service UART in ISR.
I run my program in VMware on DOS. And my program can read serial data using polling method(COM1). So data is comming. But My program dont jump to ISR.
I put my code here,
thanks for your help
I also check IRQ addresses with MSD.exe. All of them is changed to my program ISR.
I think no Interrupt is enabled.
please help
I put my code here,
INI_UART_COM1 MACRO
;intialization of uart COM1
;maped to 3F8H and IRQ4 (I.V.T add=C)
;set dlab=1
MOV DX,3FBH
MOV AL,10000000B
OUT DX,AL
;set devisors (64)(10800 buad rate)
MOV DX,3F8H
MOV AL,40H
OUT DX,AL
MOV DX,3F9H
MOV AL,00H
OUT DX,AL
;clr dlab-no parity-1stop-8bit data
MOV DX,3FBH
MOV AL,00000011B
OUT DX,AL
;set interupt for reci. data
MOV DX,3F9H
MOV AL,0000_0001B
OUT DX,AL
ENDM
INI_UART_COM2 MACRO
;intialization of uart COM2
;maped to 3F8H and IRQ3 (I.V.T add=B)
;set dlab=1
MOV DX,2FBH
MOV AL,10000000B
OUT DX,AL
MOV DX,2F8H
MOV AL,40H
OUT DX,AL
MOV DX,2F9H
MOV AL,00H
OUT DX,AL
MOV DX,2FBH
MOV AL,00000011B
OUT DX,AL
MOV DX,2F9H
MOV AL,01H
OUT DX,AL
ENDM
;;my code without begining!!
IN AL,21H
AND AL,1110_0111B
OUT 21H,AL
INI_UART_COM1
INI_UART_COM2
;SET IVT TABLE
MOV AX,0000H
MOV ES,AX
MOV WORD PTR ES:[0030H],OFFSET COM1_INT
MOV WORD PTR ES:[0032H],SEG COM1_INT
MOV WORD PTR ES:[002CH],OFFSET COM2_INT
MOV WORD PTR ES:[002EH],SEG COM2_INT
MOV AH,02H
MOV DL,CR
INT 21H
STI
MOO: NOP
JMP MOO
COM1_INT PROC FAR
MOV AH,02H
MOV DL,'r'
INT 21H
MOV DX,3F8H
IN AL,DX
MOV AH,02H
MOV DL,AL
INT 21H
MOV AL,20H
OUT 20H,AL
JMP COM1_INT
COM1_NO_INT: STI
IRET
COM1_INT ENDP
please help
