Programming com port in c# for sending data to micro
asic1984
Full Member level 5
Full Member level 5
c# com port
hi
i need to learn programming com port in c# to send data with it for microcontroller
so if any one know a good site or tutorial or example this will be very helpful
thanks for your help
c# - com port
Dear asic1984,
Here it is (article and source code):
SERIAL COMM
Use P/Invoke to Develop a .NET Base Class Library for Serial Device Communications
by John Hind
h**p://msdn.microsoft.com/msdnmag/issues/02/10/NETSerialComm/default.aspx
The best article for controling an RS232 port from managed code (C#).
It was tested by me from a long time and the code works 100% (even in Win98!!).
There are many articles about this subject on Internet, but many of them contain mistakes, therefore i highly recomend U this one, for a starting point to your projects!!
Re: c# com port?
You can use the standard procedure for accessing Serial Port through CreateFile, OpenFile WinAPI functions. This is the general method to work with serial port under WinXP and it works anytime.
