Programmer for AT89S53
DrWhoF
Advanced Member level 1
at89s53 programmer
Need good programmer for 89S53.
at89s53
This one is quite simple and includes the AT89S53 ..
All what you need is access to the parallel port, 4MHz crystal, 74HCT541 buffer, 1 PNP transistor and a few resistors ..
Regards,
IanP
    DrWhoF
at89s53 isp programming
Check this site:
It's Polish. However it's excellant and supports 89Sxx and AVR.
    DrWhoF
at89s53 lockbits
Also try ponyprogrammer it is so easy
    DrWhoF
isp at89s53
If AT89S53 was programmed before with lock bits set will I be able to program it again using ISP programmer?
isp at89s53 cheap
Yes you may erase and re-programme the device as many times as you like even if its lock bits are set. However you cannot read its content if its locked.
isp at89s53
Programmer available at
h**p://www.amwaw.edu.pl/~adybkows/elka/ispprog.html is nice. I tried it myself with 89S52 and 89S8253 running at Vdd=3.3V.
I have made a DIY PCB layout that you may use to make a ISP programmer yourself either by strip wires or chemical etching. See attached.
John Leung
www.TechToys.com.hk
