We have a DE0 board and the manual is quite straight forward. Consider this simple counter code
library ieee;
use ieee.std_logic_1164.all;
entity counter2 is
port( clk, rst: in std_logic;
q: out integer range 0 to 31);
end;
architecture x of counter2 is
begin
process( clk, rst )
variable tmp: integer := 0;
begin
if ( rst = '1' ) then
tmp := 0;
elsif (clk'event and clk = '1') then
tmp := tmp + 1;
if ( tmp = 32 ) then
tmp := 0;
end if;
end if;
q <= tmp;
end process;
end;
According to the manual, the push button pins are described in page 27 fig 4-5
F1 -> CLK
G3 -> RST
And the LEDs are described in page 28, fig 4-8 (J1, J2, J3, H1, F2). I configured the chip with these pins. As you can see in the attached picture, the programming phase is done successfully and I see that board initial works (flashing leds) are stopped for programming. However, as I press the buttons, the LEDs don't work. If you look at the attached board picture, the five bits (output q) are turned off which shows the board is configured.
I guess you didn't realize the Button operation is inverted, signal goes to '0' when pressed. Respectively your design is hold in reset permanently unless you hold Button1 down.
There are somethings to consider.
1> What is your clock frequency and how are you supplying the clock? If the freq is too high, the blinking of LEDs might be too fast for the human eye to register.
2> Avoid using variables. Use signals (you can do almost everything with signals). The code would be better off as
tmp := 0;
elsif (rising_edge'clk) then
tmp := 0;
else
tmp := tmp + 1;
end if;
end if;
