gilbertomaldito
Full Member level 3
- Joined
- Aug 21, 2006
- Messages
- 159
- Helped
- 4
- Reputation
- 8
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 2,385
Hi Andrew,andrew_matiga said:Anyway do you have the circuit for it?
Hi Andrew,andrew_matiga said:Do you know what the "T" pin in the DFF is for?
You have to look at the circuit function to understand the meaning of the D and T inputs. It's actually a T Flip-Flop with an asynchronous preset.Is it a combination of a D and T flipflop?
As a fact, they are negated (negedge respectively active low) at the FF block. Find out what it means for the overall function.what do you mean when you say the C and T are negated
Hi Andrew,andrew_matiga said:Do you happen to have the transmission gate circuit for the T-flipflop with asynchronous preset as you have described? or at least the logic gates circuit?
I think it's better and easier to multiply the output signal by 2 : feed your divider output through a D-FF clock-controlled by the divider input signal, by this you should get the output delayed by one cycle of the input signal. Then you exor both signals (divider_output exor delayed_divider_output) and you attain a double frequency signal which can be divided by 2 for a 50% duty cycle.yego said:You could multiply your input signal by 2 before dividing it ...
erikl said:I think it's better and easier to multiply the output signal by 2 : feed your divider output through a D-FF clock-controlled by the divider input signal, by this you should get the output delayed by one cycle of the input signal. Then you exor both signals (divider_output exor delayed_divider_output) and you attain a double frequency signal which can be divided by 2 for a 50% duty cycle.yego said:You could multiply your input signal by 2 before dividing it ...
Oh, sorry: This wouldn't work for a division ratio of 1 ;-)
Hi Andrew,andrew_matiga said:I dit what you told me, however, I still cant get the correct output with 50% duty cycle.
Of course you must make sure by postLayout simulation, that you have enough min. delay for ffP, max.V, min.T, and - for your max. input frequency - not too much delay for ssP, min.V & max.T cond.andrew_matiga said:Im not confident with the delay especially becuase it may be varying through PVT.
