programmable DC power source
ashoksj
Newbie level 1
Newbie level 1
We need Pulse dc Power source i/p 3ph , 415 V , 50 Hz
O/p : 0- 1000V , should be able to source peak current 700 amps , o/p needed Dc pulses of 50 msec each.It should deliver constant power.irrespective of voltage level ( min or max ).
MODERATOR ACTION: Warning!
Select correct section before posting
Read rules, announcements etc.
What's your application??
If you make DC of 415 volts AC you get approx. 560 to 590 volts maximun , if you put filter capacitors.
1000 v X 700 AMP 700 KW, such power can rum a small factory, or full fill the requirment of small village.
are you have some lasser aplication.
