Programable function gen plus freq counter based on PIC
Fragrance
East Of Earth
xr2206 orcad
Hi all
Here is the nice thing programmable Function Generator based on PIC micro 16f877 and Max-038.
Frequency counter built in all parameters and selection display on LCD use full tool for workbench, code slightly revised and converted to MPASM compatibility.
All information about the constructions included along with source code for PIC micro PCB design included in pdf. (Note: I have built this having no problem with it)
icl8083
Hi
please send the specification of the FG and counter before we download
it.
xr2206 pic
Hi
For short info you can check here: YYY.epemag.com/projects.html go down to July 2000.
I haven't build this design but a similar from elektor with same chip, I am satisfied. I think it is good for hobby/semi pro use.
If you have problem DL this file the asm and hex code is available at thei HP, if you like to check.
Reactions: ossd and prubi
    Fragrance
    prubi
    ossd
max038 project
Perfect project, I have built 4 and all is working fine!
max038 pic
How does this design differ from the MAXIM appnote on the MAX038?
thx!
pic based function generator with lcd
have some old icl8038 from Harris. Are they pin to pin compitable with max038?
Can I replace them in ref design?
pic gen frequency generator and counter
there is no compitability with icl8083 from harris the max038 is more power full chip and have more ferquency 20Mhz in out put
pic based frequency counter
Hi
Maxim released a SMD version, for project search elektor. This is not as advanced as the old MAX038 project, mostly freq generator, but much smaller and better stability.
Cl
xr2206 pic* lcd function
Hello,
i have build an Frequency generator, too. Use PIC to display Frequency.
now i want to add the some keys, so i can change the frequency digitaly. anyone done something like that?
have some problems.
thanks Blixman
freq gen
Hello, I am going to build this generator and hope it should work. You, who build this in the past, get some info or photos. Thanks. Ivo.\]
+xr2206 pic* lcd function
Look at this!!! it is interesting with full pcb!!!!!!!!!! and code!!!
Ready to build!!!
max
pic based frequency meter
Can I Build Pic gen 753Mhz by MCU?
programable counter
Try xr2206 with pic using digital potentiometer from xicor. It will result in a perfect function generator.
pic-gen frequency generator and counter
i'm doing about system function generator base on Max038 but i get trouble about designed. i referenced some of circuit but i have no experient about high frequency. The signal is testing on digital osilloscope more distored in frequency about 1.5MHz
the circuit i designed on ORCAD (I sent blow). Could you show me my fault ?
Thank!
max038 pin to pin
Hi
pic based 200 mhz signal generator
It's a nice project. I will build it. Thanks for the files!
Added after 27 minutes:
Well, this point system is really aggravating. I'm a new user (registered 2 days ago). I was happy when I found this forum. I'm searching some information on the PIC based MAX038 generator, I found usable info only here. But I can not download any files from here, since I haven't got enogh points.
Please can anyone send the files to : adlertag_at_freemail_dot_hu ? I would be very grateful. or links, or something...
Thanks in advance!!
adlertag
Added after 4 hours 30 minutes:
bbarney, thank you very-very-very much!!!!
:D
The XR2206 is not comparable to MAX038 because the XR2206 has a max frequency of 1 MHz; the MAX038 goes to 20 MHz or higher.
max038 similar
Have any of you (please) the FG specs. Is there a supplier for the circuit board?
Thanks so much
