Program for reading/writing to serial eeprom
hassan1980
Full Member level 4
Full Member level 4
Serial Eeprom
I want an asm program for reading and writing to serial eeprom for example 24C64 and pic 16F84.
Re: Serial Eeprom
hi...
i'm beginner in pic world ...but i'm going to build data logger project...
my idea is to use PIC16F88 that have i2c...compare to the F84..
my question is..is there any subroutine to read and write a data to/from external eeprom such 24L64?
thanks in advance
    hassan1980
Re: Serial Eeprom
here is the code in C on how to Read and Write to the internal eeprom of the PIC:
void my_eeprom_write (char addr, char value)
while(WR)
continue;
EEADR=(addr);
EEDATA=(value);
EECON1&=0x7F;
CARRY=0;
if(GIE)
CARRY=1;
GIE=0;
WREN=1;
EECON2=0x55;
EECON2=0xAA;
WR=1;
asm("nop");
asm("nop");
if(CARRY)
GIE=1;
WREN=0;
* EEPROM_READ_Function *
unsigned char my_eeprom_read (char addr)
while(WR)
continue;
EEADR=addr;
EECON1&=0x7F;
RD=1;
//EEDATA;
return(EEDATA);
For external use the I2C.
Reactions: fenster
    hassan1980
    fenster
Re: Serial Eeprom
thanks a lot...
but the thing is...i try to run using assembly..
anybody...
one more thing..software routine i2c is more stable than hardware i2c?..
thanks in advance
Re: Serial Eeprom
1. I made the code into assambly for the PIC16F88. attached is the complete output from the debuger in asm. you will have to retrive the code from there.
Hardware is alswys more stable then software, aslo the hardware gives you more time to use the MCU then spend it on unwanted things.
Good luck.
Re: Serial Eeprom
thanks..
but if i'm not mistake..this on efor internal eeprom..
i'm looking to the interface with external eeprom using internal hardware approach..like pi16f88 with 24LC512
thanks in advance
Serial Eeprom
Well if you are using 24LC512 Then you must be using I2C. So, what you need is the I2C protocol.
To find out more how to do that go to:
www.microchipc.com
Good luck.
