hi
i don't mention simulink
i have heared that there is a program convert a Matlab program to aVHDL
can you upload it or tell me where i can download this program....
I gave you the answer to convert from matlab language to VHDL there is only one program Acceldsp ..There is no other !.But don't go THINKING that it will convert every MATLAB FUNCTION there is ..the reason is some matlab callable functions are not written in matlab language ,but for speed purposes are optimized in native machine language ..So there is no POSIBILITY of recovering that CODE !
I think AccelDSP is not an enough solution for complex .m files. You should model your algorithm in a signal flow diagram manner and then try to write your own VHDL code for each block in your diagram. Then verify with ModelSim simulator or any other simulation tool then verify the results by comparing with Matlab output. This is what i am doing now. It seems time consuming but i have tried too many ways. If anyone has a better idea i want to now.
There are two tools in my knowledge that can convert MATLAB code to VHDL.
(1) AccelDSP (From Xilinx)
(2) System generator
Here AccelDSp comes from Xilinx and its a very costly software. U can request for a 30 day evaluation product from www.Xilinx.com
Xilinx System generator Does not exactly convert Matlab code , it convert only Xilinx blockset based desgn to VHDL or bitstream, Again the trial version available from Xilinx.com
Other vendors must be providing their tools, Please search the internet for details reg that.
Link to ModelSim is for CoSimulation between the Simulink design and the VHDL design blocks. That is my view.
in my kownledge you can use matlab hdl coder or search the internet for match compiler that convert matlab code to vhdl or convert matlab to c then use stream c program
i think there's a trick we can do, we can build our program made in matlab to a c++ native, then export to another program like ALDEC HDL, and convert to VHDL, i think it works better if we convert from c++ to vhdl, than matlab, althought matlab uses C, but not the nativeone... if im wrong please someone !... thats just an idea...
