process porting - *WARNING* Invalid type (string)
jeremy_zhu
Member level 2
Member level 2
process porting
in my porting , for example smic18-->smic13,
in Scematic editing window: edit->search->replace (master mode porting).
after porting : a 4X inverter , the Multiplicity in CDF shows 1 but in netlist generated by ADE is 4 ( 4 is correct) , why the cdf is not updated correctly and in time.
and in CIW window: a warning below ocurres when you select a MOS and see the properties
(Q, bindkey)
*WARNING* Invalid type (string) for property 'm' on instance 'P0'
